RSLogix Compare small difference between two modul
Kataeb
Jan 2007
www.livelovelebanon.com
636
RSLogix Compare of two projects, resulted in difference between two Rockwell 1756-OB16IS modules with the following property values: InputData, InputForceData, OutputData, OutputForceData.
is this serious? can i work on either project as if they were the same, ignoring this minor difference?
Well, what is different?
It's an output module.
Outputs turn on and off via the program.
The current state is saved when you save a program.
Did you save both programs when the machines were in an absolutely identical state?
actually one of them is a fresh upload of the plc, while the other was delivered by the supplier of the machine. so we can conclude that they are identical. but as Rockwell upload gets all the information with comments and symbols, i will work on it with ease. thanks
Howdy Everyone, We are working on a project in rslogix 5000 where we are using an rfid reader to read the barcodes then if they are on a list of...
2,538
Hello, Currently on my laptop have rslogix 5000 v16_20 and I'm not able to see the compare sheet of parameter for vfd powerflex 40p over comm e...
1,287
Hey there, I'm trying to compare the amount of counts in any 5 minute period. What I'm doing so far is when each count is made true, a binary...
2,673
RSLogix compare tool: "exception of type 'system.outofmemoryexception' was thrown Hi Everyone, As in title - During programs comparation RSLogix...
4,575
I get the following xml error evertime I try to compare files. I have tried serval versions of the software and still get the same error...
4,475
