RSLogix - Data File Statistics
arthur2
Feb 2006
Oneonta, NY
I have attached a print screen of the data file statistics from RSLogix 500. I selected a MicroLogix 1200 Series A. Can anyone tell me the reason why the number of Elements (Elems) in the I/O file type column's do not match the number of Words in the WORDS column? Given that MicroLogix and SLC-500 series controllers have one-word elements for both the input and output data file types, I have been unable to find the answer. I realize that some words may be reserved depending on the MicroLogix model or series, but even a SLC-500 system configured with one input or output card comes up with 3 words to 1 element. I sure would appreciate any help as my students would also benefit. arthur2
Just a guess but since it looks like the number of words is 3 times the number of elements that one set is for the state according to the program, one set is the force state and the last is the actual state (based on whether you are forcing the output or not).
I went back to RSLogix 500 to check out your theory and I believe you are almost 100% correct. I'm thinking that the final answer may be that each input or output element or word is made up of three words that you have indicated that include the: State or status of the actual "Data File" word (as you indicated), Force state of bits within the "FORCES" word (as you indicated), and which bits are being used in the program within another "Usage" word based on the layout and descriptions contained within the dialog boxes of RSLogix 500. Thanks again for your help!
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
782
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,200
Hi Guys! Does anyone know which version of RSLogix 500 i can insert ASCII DataFile? I'm using 10.0 version and i not found this DataFile, but...
1,450
Hello everyone. This might be a silly question for many of you here. I have created 2 separate ladders. One to control one part of the machine...
2,404
Hi all, Im trying to add some more elements to a Floating point data file without much success. Its already set up for F8:0 only. I would like to...
3,356
