RSLogix FSC.IN reset
Hutber
Apr 2008
Milton Keynes
I am having trouble using the FSC instruction in RsLOgix 5000.I need to reset the FSC.IN to anable me to find the next match ,I can toggle the bit and it works , as soon as I use a OTE its held off , no good , I need a indirect method , like MOV of CLR for a word .
use an OTU.
it may appear as though it is "held off" as you call it, but it will be on from the time the FSC found the first match, until the time you turn it off with the OTU.
place your code that deals with the finding of a match between the FSC instruction and the OTU of the .IN bit.
Hi there. In RSLogix 5000 i have an array of barcodes, and used an FSC bit to find which array position an input barcode matches. However when the...
2,806
Hello, Please Help! I have an array of 20 registers that I want to search for a value. There will be over 100 DINTS Values that come in and if the...
1,831
Hello Please Help, I want to use a FSC instruction that will scan 20 DINT arrays. If the arrays are greater than 1000 display the value. How do I...
1,786
Hello All, Does anyone know why FAL and FSC instructions are part of the instruction set for RSLogix 5 and 5000, but not for 500? I have an...
3,327
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
79
