RSLogix Starter Print I/O List
Again, unsure about Starter (especially since you can't take AB's literature as gospel)
Alternative method to John (Thornton)'s:
SaveAs Library file (.ACH). Check "Export Database" box on dialog box.
Rick's method DOES work in the starter package...
Look up "CSV Format for Import/Export" in the help file to figure out the field names.
beerchug
-Eric
If you just want a quick printout then just
  1. open your project
  2. Scroll down the Project Tree to the Database folder and double-click on Address/Symbol
  3. With the Address and Symbol Database open click on File and Print Preview to view the printout before printing
    [/list=1]
    This will print out all addresses that have been documented with either a symbol or an address description.
    OG
Thats what I needed, also its good to know you can get a comma delimited file using the database export...
Thanks to all
John
    [/list=1]
    OG
If you goto file/report options/program files you will also be able to print out address's/descriptions etc,along with other options.
However beware and check only what you want to print as you may have to wait all day if you check everything.You can also print out ladder logic and only for the rungs you select.
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,713
Hello all, I am new here and a beginner when it comes to PLC's. I have an RSS file from an former project we have done but I can not open it with...
2,284
Oh, I hope someone can help! I have one little problem holding me up from studying this weekend. I'm using Rslogix micro starter light, it's a...
3,005
I am using RSlogix Micro Starter for a personal project and currently have it installed on a desktop computer. Soon I will be moving my project...
2,215
Hello, I'm using RSLogix Micro Starter Lite and am attempting to update the RI data table. Is this due to the fact that it's a light version and...
1,184
