RSLogix5000 Basic Question
kittydog42
Sep 2005
Naperville
232
Is there a way to write multiple tags to 0? With the TSX37 Modicon, I would write %MW0:10:=0, for example, to indicate that I wanted to write 0 to %MW0 through %MW9. What I am actually trying to do is write 0 to multiple elements of an array to clear it out, but not necessarily starting at offset 0.
If the array is of a basic numeric type the the FLL should allow you to do what you want. If it is a user defined structure then create a zeroed copy of your UDT in a tag then use the COP command.
ya its easy,
you have to map the word/bit(which and all you want to move zer), into systamatic way (with free bits in the word starting from 0 say WX:0 to WN:0)and then you can use COP instruction to copy number of elements you wish to copy with ZERO 0.
Here WX=ANY STARTING WORD (STARTING FROM ZERO)
WN-END WORD
WX AND WN=SHOULD BE UNUSED.
thanks for your understanding.
Naag.
from an email: this is a fairly common question - and since I'm swamped with other projects right now, I've decided to post my answer to...
5,918
Greetings to all ... I got this in a PM the other day ... since the question is a rather common one, I decided to answer it here in the open...
16,244
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
195
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
184
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
513
