RSLogix5000 FBD Programming
MartB
Jun 2005
Pinellas Park, FL
684
Ok, I've only recently discovered the delights of this software and I have a question that'll probably be so easy for you guys.
Basically I want to know if this will work, and if not, why not.
Like I said I'm very inexperienced with this software and I'm trying to see if I'm understanding it correctly.
It's also loosley connected to a project I'll be working on shortly.
Thanks Alaric, just wanted confirmation. I'm really not that dumb but sometimes a little self doubt can creep in the longer you look at something! :unsure:
The FBD will work as shown but if you are using a CLX(1756) analogue input card you can perform the entire operation in the card without any code. If you are using a different analogue input card then disregard this.
Ok thanks I'll bear that in mind Andybr. Not sure which card we'll be using as the machine is still in the design stage (I'm only a programmer and I have no input on the design phase of a project - which really sucks sometimes).
Hi, RSLogix5000 v20.01 FBD editor is making me crazy when it scrolls up or down automatically each time I move a block or a tag or even delete a...
1,287
I am curious as to how many of you actually utilize the SFC and FBD available in RSLogix5000. I find both very useful depending on the task at...
2,331
Good day all. I would like to know if it is possible to change programming languages in RSLogix5000? For example, if a program is written using...
4,881
Hi, I have a project using RSLogix Function Block Diagram and a Prosoft Profibus module to communicate with a Siemens DCS My problem is it has...
14,056
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
188
