RSLogix5000 Function Block Wire Auto-Routing
Zlinger
Mar 2014
AZ
36
I'm modifying my first function block program in RSLogix (I've only done ladder and ST on the AB PLCs before). The existing program looks like a Family Circus cartoon in places. Wires that should be very short are wrapped all the way around the page three times before the land on a function block. What causes this? How can I keep my modifications looking like this when I have to come back and modify it again at some point?
You can (to some extent) drag the wire-lines where you want them.
Why does it do the insane things it does? Only Rockwell knows, and probably not even them.
Yeah, I can rearrange the blocks and wires easy enough, but it's just annoying and should be unnecessary. So far, I am not impressed with Rockwell's function block editor. Seems pretty clunky and glitchy.
I've never understood why it runs a "verify program" every time I cut and paste in the FBD editor. And "crazy line syndrome" is extremely annoying.
Still, I prefer able to use "insert" and a mnemonic rather than digging through tool boxes...
Hello I'm trying to use function blocks to scale engineering units to W.C. reading. but I don't see the option to create the function block is...
1,062
I have not used function blocks much in Studio 5000. Could someone tell me the advantages compared to the dis-advantages.
1,417
Anyone know of an easy way to program a FIFO in function block for RSLOGIX500. There appears to be no instruction for this. I'm sure I can put...
2,813
I'm making a quick foray into using a FBD routine in order to use the SCL instruction and I found a couple things I could not find an explanation...
6,750
hi I am unable to view function block diagram i.e. boolean functions I've installed version v13.04.00 The installed components are Ladder...
3,869
