RSLogix5000 GSV
mitch11
Mar 2017
Ohio
26
Hello all,
Could someone further explain how to use the GSV instruction in RSLogix.
For example, if I want to monitor the communication status between the PLC and a VFD, I have read that you can use a GSV. Class name module, and attribute name EntryStatus.
How am I supposed to know what the value that I receive back means? What value indicates communication is OK? Not OK?
Like I said above, this is just one example of the GSV. What if I wanted to monitor the status of the controller? What value indicates minor fault, major fault, program mode, run mode, etc.
Thanks for any information! 🍻
In the Studio 5000 Help file, the "GSV/SSV Objects" section is really good for both reference info and examples.
As a more general matter, I recommend two of the Programming Manuals:
1756-PM014: Logix 5000 Controllers Major, Minor, and I/O Faults
1756-PM015: Logix 5000 Controllers Information and Status Programming Manual
Doesn't matter what the value back means - read anything - if the MSG.DN is true, then you have comms, if the MSG.ER is true you haven't, monitor that to latch an alarm bit.
Here's one I use, it also includes to not to set the alarm bit if the drive is inhibited:
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
910
hi i want to knw the use GSV instruction class...
5,921
Hello everyone, Wondering if anybody can help me with this: I have a CompactLogix processor running a little robot cell. Every 200 cycles...
186
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
180
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
487
