RSLogix5000 Hex Int to ASCII
WPI-Wesley
Jul 2017
Groningen
Hey,
i've been working on getting some add-on instructions defaulted in the company i work in. i am currently trying to create a string which shows the status of a connected module.
the status is shown in a HexInt ex.: 16#4000
in this case 16#4000 = Connected and ready.
i compare the status with that value, and if 16#4000 is true, i write "Connected" to a status string.
whenever the value is not 16#4000 i want to write that actual status into a string. as Rockwell uses these hex codes in all of their manuals, so the costumer can easily troubleshoot why the module is not communicating.
when i want to write one of these error states: ex.: 16#0000
i want the string to show 16#4000.
i tried the COP or DTOS commands.
COP comes up with a string i dont even know the size of.
DTOS shows: 4096.
how do i get the string to show the actual HexInt value of "16#0000"
in the picture you'll see a lot of double names. but that is because it is an Add-On. (instance name comes from an Add-On input. DEST EntryStatus is a local tag)
How many possible statuses are there? If it's not too many, I would just do an EQU for each one and write either the error code as a literal string, or even better the error code description. DTOS is writing the decimal value of the code and I don't believe there is any way for it to write the hex value.
For this particular module not too many.
But i want to make it an all-round instruction for all modules used.
The status i am using is for the connection state to a module inside the PLC network.
+ side of being able to write the codes is that Rockwell support websites and manuals reference to the Hexa codes.
In that case, I would write another AOI/FB that would take a decimal input and output a string with the hex equivalent, though how exactly I'm not positive though I'm sure some googling will turn up the math. I'd guess that this would be a lot easier to do in Structured Text.
Just use the SINT value by itself without converting it to a STRING when retrieving the modules' status.
Use the TOD (Convert to BCD) instruction when you need to 'analyze' the SINT values modules' status depending of the GSV returned hexadecimal value.
I have no experience with the BCD datatype, how exactly do you analize an Int with BCD?
The goal i had was to make a string for the HMI's.
when connection is OK (16#4000) it would show "Connected" as string.
if not, it shows the error code in string format.
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
129
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
435
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,127
Good Morning Everyone, I'm looking to use the GSV instruction to get I/O fault codes for my project so I know if there's a comms issue in my E/IP...
874
The machine is running production. When trying to go online with the laptop the whole machine looses communication and faults out. Drives, HMI...
1,948
