Rslogix5000 motion
ghriver
Aug 2002
Earth>North America>US>CA>Hanford
65
Hi all. This is a machine programmed by the manufacturer. There is an event task and the event tag is a MOTION_GROUP tag. Screenshot
. Since the tag contains many sub(?) tags, does that mean any tag in the array of tags changes value then the event-based task will execute?
As I understand it, the Motion Group Execution trigger is not a change-of-state detector for all of those sub tags.
Instead, using a Motion Group as the execution trigger for an Event task causes the Event Task to execute at the same period as the Motion Group's Base Update Period.
Usually the Motion Group interrupts everything else, so the Event task runs immediately after it.
But I think you can invert that with Priority values.
The basic explanation starts on Page 43 of the Logix 5000 Controllers, Tasks, Programs, and Routines manual.
https://literature.rockwellautomation.com/idc/groups/literature/documents/pm/1756-pm005_-en-p.pdf
Motion control by RSLogix5000,Compactlogix 5370 L3 Controller & 2097-V31PR2-LM Drive Hello! I would like to study the Motion control by using...
4,239
Hey everybody, I've been working with process and packaging for years, but I'm fairly new to motion control, and would like some quick advice on...
3,805
Hi Guys, Try to learn Motion control for RSLogix5000, where should I start from? I am reading the MotionInstruction now. And one more question...
3,410
I could not get a PC (process complete) bit to turn on after a MAM command. This only happens on one of the many MAM commands on the same axis...
3,481
I have trouble to get a Process Complete bit to turn on after a MAM. This only happens on one of the many MAM commands on the same axis. Could...
1,680
