RsLogix5000 : Stop polling an equipment
pierrer
Nov 2018
Quebec
I'm trying to set up a new equipment (Thermal camera : Flir AX8) and there seems to be some matching problem between the two. When i need to restart the camera (when she is read by a PLC), it seems like the PLC is sending data to the camera and she's not having good reading.
However, if i unplug my PLC and restart the camera, the readings coming from the camera seems just fine.
So my question is: Is there a way to interrupt a plc running RsLogix5000 to try to poll an equipment in particular? My objective would be to detect an error x (example: the camera lost his ability to read the temperature) coming from the camera, then i would stop the PLC from polling the camera to restart the camera and then restart the polling of data from the camera after a certain amount of time.
Is there someone that had to do something like this before? Let me know if you already have pull off something like this or if you need any more details regarding my problem.
Thanks in advance.
Hi, I have 2 safety devices (Banner EZ LS light curtains and a Keyence GS-71 Interlock) that are giving me some difficulties. The plc is a Compact...
1,986
Basically I know that I need a GSV but I still Don't know how to set the time to stop the pump. The pump has to stop certain day at certain hours...
2,733
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
128
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
428
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,126
