RSLogix5000 version selection
hanziou
May 2005
111
I have look at the Allen-Bradley Site and found a matrix that compares the different versions of the RSLogix5k.
http://literature.rockwellautomation.com/idc/groups/literature/documents/sg/1769-sg001_-en-p.pdf#xml=http://127.0.0.1/texis/search/pdfhi.txt?query=1769-SG001E&pr=literature.rockwellautomation.com&prox=page&rorder=500&rprox=750&rdfreq=0&rwfreq=0&rlead=250&sufs=1&order=r&cq=&id=43a5b978a
(p.39 = 41st page of the pdf)
I am looking to use CompactLogix controllers so for now I was thinking that I could use either to Mini Edition or the Lite Edition.
I will be converting an Automation Direct application to Allen Bradley. (Customer's desire)
Is ther anything in the Lite or standard that I would need that isn't in the Mini. How useful are the Function Block Editor, Sequential function chart editor, and structured text editor to someone who works in ladder logic.
I am just looking at analog inputs (TC and 0-10V) and 120VAC inputs and outputs. Nothing needs to be updated more often than every second or so. I will want to run a few PID loops.
No there is a PID instruction in ladder, But I was just saying I prefer the PIDE block in FBD. You can have the PIDE autotune your loop if you have the right package.
You can use the ladder based PID loops without FBD, but the enhanced PID (PIDE) provides some additional features like auto-tuning and much more complex configuration (handy for cascade loops). If you are trying to compare it with the PID in Automation Direct I would expect it to be similar for the ladder based PID that does not require FBD.
Darren
My comptuer is 64 bit OS and Install studio5000 versio 30. my question is can I install version 19 software on it? Anyone have run version 19 on...
2,708
Hello, I am wondering which version of RSLinx I should download to use with RSLogix5000 Version 17? Thanks!
2,151
I am unable to convert a project to V20 using the following procedure. Open a project in version 19. Right click on processor 1769-L35E ECP...
4,913
A guy is telling me if a ControlLogix 5000 was programmed with version 15 RSLogix 5000 you need Ver 15 RSLogix 5000 to open it That version 19...
6,318
hi friends I'm doing a conversion program to S5 platform for RSLogix 5000 and this SLT above is an example. :A =KM :LW =KC :SEC =CONT : :A...
1,842
