RSS File
keKlon
Mar 2018
Connecticut
Hello,
Will someone please help me. I would like to view an RSS file. I am trying to update an old Allen Bradley SLC 5/04 PLC to an Automation Direct PLC and I don't have the software to read the AB program. I will paste a zip file of the RSS. Can someone please convert it to PDF format? Thank You.View attachment SACB1-010109.zip
see if this helps ...
and a tip ... your original Allen-Bradley file makes use of quite a few OTL and OTU (latch and unlatch) instructions ... the nearest thing that the Automation Direct platform has to these would be the SET and RST (set and reset) instructions ... many people believe that the AB and the AD instructions can simply be used interchangeably when making a translation between one PLC manufacturer and the other ...
this is WRONG - and can lead to some serious safety issues related to "retentive" and "non-retentive" operations ... you really should read the following thread to see how differently these two manufacturers handle these ideas ...
http://www.plctalk.net/qanda/showthread.php?p=71786&postcount=1
good luck with your project ... and welcome to the forum ...
Good Morning, I have a Micrologix 1400 .rss program file, that I need to get the print out of the program and I also would like to have this...
149
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
125
Hello, Would someone please kindly convert an RSS file I have to an SLC file for me? I've asked around and no one has the software here for...
963
Today I'm working with a MicroLogix 1400. I don't have the .rss file since we did not program the system. I was able to get the FactoryTalk file...
1,107
Hi, I only have the RSLogix Micro starter edition and cannot save as .SLC for the micrologix to micro800 conversion tool on CCW. I would be very...
2,546
