RSView Studio Application copy
kupeyy
Oct 2006
Lancaster
19
I have created a program in RSView Studio Machine Edition and I need to copy that application for backup purposes and to transfer it to a new machine. Now I found the project file, but I am not able to copy it and then open the copy
I also looked into taking a runtime file and restoring it with no luck. One other thing I was trying was using the application manager to create a copy.
Unfortunatly I was not successful in copying an application and then restoring it. Can anyone give me some direction?
Is this the error you are seeing? I tried to copy an ME application using the application manager and received this error. But without RSView Studio running and using the application manager I could create a backup
If so, then you must launch Application manager as a separate program without RsView Studio running
You will find the application here:
Ian
Use the Application Manager and create a Backup. This will create one file that contains your entire project. Copy that file to another PC and perform a Restore.
Copy is really only intended to copy to a new project on the same PC.
OG
I appreciate all this help. I actually figured it out browsing around on my own before I seen the previous two posts. Both were right on my money. I got the file backed up and restored successfully
Thank you for your help!
Hi All, I am running windows XP (sp3) and RSView Studio ME 4.0 Using the Application Manager I am trying to 'delete an application', I select...
4,517
Hello, I just received a PanelView application in the form of a .PVA file, and would like to take a look at it. I have RSView Studio installed...
5,052
Hi there, I've been trying to create a new application on RSView Studio ME, but everytime I click on 'Create', the whole program would close...
3,966
Hi there, has anyone encountered the following message when trying to restore a .apa file in RS View application manager: "Unable to restore...
10,544
Hello, How can I testing a RSView studio application on a Remote I/O network with a PLC5/25? The application will later download to a...
8,260
