RSView32 ActiveX Error
Olga
Aug 2018
Glasgow
I have a problem. When I try to open one of my graphic displays I get an error:
''Unable to load ActiveX control for display [Display Name].
cause: RSView32/SE Idle Detect Control: ActiveX control not found on computer.''
I've never worked with RSView32 before and I have no idea how to solve this issue.
Help! Please!:(
The Idle detect is an Active X plugin for RSView32, it is often used to logout current user, and log in a view only user. It sounds like someone migrated or updated your project to a new PC/Server, and did not install the Active X plugin. You need to install the plugin.
Thank you Ken,
Would you happen to know where I can download this ActiveX plugin? And which folder should I save it to?
The virtual machine that I am using for this has Windows XP on it.
Sorry, but I am a complete beginner here...
I do not have a folder ActiveX Control Setup and there is no file with the name of IdleDetect.ocx.
Also when I try to create an ActiveX object I get an error message saying 'failed to create ActiveX object'.
And in the 'Insert an ActiveX Control' tab I have no options for RSView32/SE Idle Detect Control.
Can I download this IdleDetect.ocx from somewhere?
Thanks,
Olga
I don't see why you couldn't create the folders manually. Also, the download for the idledetect activeX control is at the bottom of the KB article that Ken linked, which does require a TechConnect contract to access. It is titled "idledetect.zip" under the attachments header.
Thank you both!!! It worked!!
Sorry, I did not notice the attachment before, that's why I was so confused.
Thank you so much!
Hi, I have a problem. When I try to open one of my graphic displays I get an error: ''Unable to load ActiveX control for display [Display Name]...
1,220
I am Using RSView 32 V6.30.17 in Windows 2000 in AB HMI. When i go to Login Page a window popup saying 'ActiveX component Can't Create Object'...
2,002
I'm very new on RSView software. Recently got a sample program, but when I try to open some graphic display (say the display file name Page01), it...
13,948
Hello All, I am trying to open some screens that uses ActiveX controls. Unfortunalty, it says the specific ActiveX control does not exist (It is...
1,675
Hi All, I am trying to get the activex "logviewer" working on RSView32 v7.1 I have installed the app today after downloading it from Rockwell...
2,039
