RSView32 and MySQL
plc_va
Jan 2008
VA
18
I want to data log to a MySQL database. MySQL is up and running along with RSView32. Does anyone have the RSView32 VB script/code that will connect to the MySQL server and write the data to it.
Save yourself the hassle and use FactorySQL. Scripting within an HMI isn't a good (or easy) way to do data logging. Rockwell would recommend RSSQL/FactoryTalk Historian (running on MS SQL Server, of course).
If you are using trendx, you just need to set up an odbc connection to the mysql server, and configure trendx to use that connection. No scripting is involved.
However, FactorySQL is a far better solution, and you can have it up and running in a matter of minutes. There support team is also top notch. Because RSView32 is also an OPC server, you can pull HMI tags or PLC tags and dump them into the database
Hi!! I have MYSQL v5 Serwer on WinXP Pro, with installed MyODBC Driver v3.51.12 and a RsView32.. And I would like to log (by using Datalog)...
4,056
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
374
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,911
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
597
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,433
