RsView32 Datalogs capacity
ivoivanac
Jul 2007
My House
Hi, I am new here so hi to all, the issue I would like to ask is the following, from rockwell support I recieved the bad news that rsview32 can handle ony 20 datalogs, I need like 60, is this rigth? because now I am having like 35 datalogs working, with no probs, but the rest of datalogs won´t excecute due to low memory condition, I added more ram (only 64) but still did not excecute more datalogs.
Kind Regards
Ivo Ivanac
My feeling is you are confusing Datalogging models with Trends.
It is true that RSView32 will handle 20 Dataloging models but those models store the data which will be used to make Trends
In my case I use Datalogging models called, Electric power, Water services, Steam services, Refrigeration, and log 200 different tag values into those 4 models
From those 4 model I create probably 100 trends.
Yes, you are rigth, I was confused there, now I will be able to log all the values I want, I am a little new to RSVIEW.
Thanks for helping.
Kind Regards
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
391
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,923
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
607
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,450
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,313
