RSView32 momentry buttons
English
Jan 2010
Nottingham
I am trying to setup RSView32 installed on a touchscreen PC connected to a AB ML1200.
The problem I have is with momentry screen buttons.
We have a function on the machine that requires to "inch" a machine through positions by holding down the screen button whilst the machine is moving. When the button is released the machine stops.
All very easy.
The problem is RSView is only allowing the rellevant tag to be energised for 10 seconds. We really need a minute or more.
So can this be adjusted? We have the same program running on other machines using the same PC and they have no issues.
Any suggestions on how this can be changed
Though you can adjust the on time of momentary button, its like an off delay. As long as the finger is on the button it is on. That is a real long time for someone to touch the screen. I am thinking if your making the operator hold the button you should reduce the button time to the min.
This maybe a feature of the touch screen itself. I know some touch screens have a timeout function to stop a touch if it is sensed for a period of time. I think this is to prevent dirt or something from keeping the touch screen from being "on" thinking someone is continuously touching it.
Maybe be a registry edit.
I would go with Paully's take as well as Smoke RSVIEW momentary push button normally keeps the tag in active state until you release your finger so this is probably a setup parameter of the touch screen maybe you might be able to extend this time without going into the registry.
After a bit of digging around a regedit sorted the screen to allow the button to be pressed for up to a minute. They have a max of 120 seconds, but as smoke said, 60 seconds is enough.
Didn't help the software though.
I have found that even if I toggle the tag in the PLC, it only remains toggled for around 10 seconds. The tag isn't used anywhere else in the program and has been used with the same address in the same ladder program for the previous 6 projects without issue.
What has confused me is that I have changed this address and everything works as it should.
Any sugestions why the original address won't work?
. . .I have found that even if I toggle the tag in the PLC, it only remains toggled for around 10 seconds. The tag isn't used anywhere else in the program and has been used with the same address in the same ladder program for the previous 6 projects without issue.
Something is writing to it. I would suspect that it is coming from RSView32. You could prove this by disconnecting the RSView32 station, and then toggle the bit and see what happens.
Since the operator must hold the button for a whole minute, perhaps you should give them a separate run/stop control?
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
392
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,924
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
608
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,451
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,314
