RSView32 on Windows XP SP3 Using OPC
dobidust
Sep 2011
Middlesbrough
44
Hi guys I have a RSview32 talking to a Logix5000 PLC using OPC which is not talking at the moment. This was previously running on a XP machine (SP unknown...its gone missing) that has gone down. I have installed all the software on a XP laptop SP3 but now we cannot see any of the tags passing through in the tags monitor we get "error", "Stale" & Uninitialized. Everything is setup as should be I can drill down in to the tags in the tags data base and we can see everything ok in RSlinx. Also when I set the topic up it now has the "padlock symbol". However I cannot get data through to the program. I have checked the DCOM settings and disabled all firewalls on the laptop but still no joy.
I'm hoping one of you guys has had the same problem and can offer a quick fix.
Can you post some screenshots of your errors? It's been a while since I used RSView32. The Windows XP service pack may make a difference. I remember one of my old coworkers had a computer with Rockwell software on it, running Win XP SP2 and he refused to upgrade it to SP3. Also can you explain what you mean by using OPC? Are you using RSLinx?
When I try to run RSView32 on a laptop, I get this error. I don't understand why it is wanting me to delete the Program Files folder. Windows 7 SP1
1,259
Hi there, I was wondering if anyone has been able to successfully install RSView32 on Windows 7... The installer completes successfully, but...
18,958
Hello... Curious if anyone has experience running RSView32 version 7.20 on a Windows 7 Professional 32bit OS. This isn't officially supported by...
4,035
Hi all, I'm on site to migrate an RSView32 application into RSView SE application. I cannot shut down the RSVIew32 application due to logging of...
5,006
Looking to see if anyone has experience using RSView32 in a Windows 7 environment. I know that it isn't blessed by Rockwell, and I know that...
5,365
