RSView32 security mystery
fredericnew
Apr 2007
athens
Hello, I am currently working with an existing project to which I am adding some feature.
the project has several users defined under the security tab with login macro assigned for different levels of access.
while troubleshooting yesterday I realized that eventhough I was logged in at the highest level possible; the display would not give me access to features restricted to this level.
this was functionning before.
Security is implemented by setting the value of a tag (Security\CurrentUserLevel) and then adding animation to some of the elements of the screen, making them invisible if the tag value is less than what is expected.
for some reason; RSView does not run the login macro even if the login is successful.
I can run the macro manually and it works perfect.
is there something obvious that I have changed on the Security tab that would prevent the execussion of the Macro?
thank you
Hi all, is there a way for an OEM to lock/prevent a RSView32 application form editing. I have a customer that says he can't modify his application...
1,679
Is it posible to apply security to a button action in RSview32.? If so, anyone have an example I have a button that sets a group of variables to...
1,879
Hi all, I need your experience, how to disable the Flying Windows button on the computer keyboard, because it is important for RSView32 security...
23,699
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
405
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,926
