RSView32 works 7.4 version -- Displaying string tag on alarm log file
pssriram16
May 2006
San Francisco Bay Area
39
I want to display a string tag in the alarm log file in RSView32 works. For exapmle, in the user custom message in the "Alarm States" tab I included this message:
\11d \8t \30s /* S:8 :: [PLC_1]g_BasketId_Unload_Station] */
where
[PLC_1] --> This is the node topic defined in RSLinx
g_BasketId_Unload_Station] --> This is the string data type tag
But this syntax is not working. Has anyone ever done this before. Thanks. Sriram.
I guess it cannot be done this way in RSView32 works. You can display strings in alarm messages only in RSView ME (now called Factory Talk View).
So what I did was create a event alarm detector that sets off the datalogon command to log the string data.
Sriram
does anyone know if it is possible to make edits to a project file that is run on a older version of runtime using a newer version of works and...
7,320
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,575
Have a server running RSView32 Works. Somehow the Menu got screwed up and when you start the program, If you don't select the right screen (with...
2,973
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
2,031
Hello all, I'm new to the site, but thankful it's here! I just installed RSView32 on my computer for the first time. I have never run any...
9,364
