rsview32
alexmuchui
Jul 2009
nairobi
I am running RSview32 scada and RSlink pro and SLC 500 PLC. when i configure a start button using PLC internal bit B3:1/0 , stop button B3:1/1 and and output as B3:1/2. When the start button is activated on the scada, the plc bit output bit responds and comes ON and scada changes colour on the configured output.
When i change the output bit on the scada tags and plc to O:2/0 or any other output on the output module, the PLC output comes on when you press the start button on the scada and goes off when you press the stop button on the scada. But the scada does not change colour.
The scada does not have any effect on external bits whether input or output even if they are configured on tag database. But if you use internal plc bits it works.
an error keeps appearing ( channel 1 error illegal command or format)
please help solve this problem.
It has been a long, long time, but I seem to recall that it is not possible to directly read the physical I and O tables from the HMI's.
Just stick with B3:1/0, B3:1/1, and put your output in parallel with B3:1/2, then read 1/2 from the HMI.
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first...
377
Hi everybody, I have a rsview32 application, when I try to run it it loads upto 80% system settings and the crashes saying Rsview32 Project...
1,914
Hi Guys I'm having trouble assigning a tag to an activex label on a Multipage Tab. I can assign the tag to an active x label on a normal display...
601
I have followed the procedure below to convert RSView32 project to FactoryTalk View...
1,439
I have converted RSV32 to FTVSE Distributed. pretty straightforward... I cant seem to figure out how or find any documentation to migrate RSV32...
2,307
