RTD-Tranducer-1746-ni4
mccecim
Apr 2010
Belem
24
I've already found the error and now this problem is solved. But
I read about the RSlogix 500 and there was something like convert to BCD (Tod) a integer variable. So, how can I use 7 segments displays to show the result? I have no idea about the hardware, Will I need many outputs?
If anyone could help...examples...
thanks a lot,
Cecim
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,207
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,652
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,094
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,067
Hello! I have RTD sensor with 4 wire and shield ( 2 red wire + 2 white wire + Shield) and I want to connect to 1734-IR2 module. But in the manual...
1,451
