Rtd
Lemming
Oct 2004
PalmerstonNorth
332
Hi
Does anyone know if a LG-NI1000 RTD's as used by Siemens in their BMS style gear can connect to a standard NI1000 compatible input??
Not sure if a NI1000 is the same as a LG-NI1000... Have come across a resistance table for the LG-NI1000, but not NI1000
https://www.cee.siemens.com/web/cz/...rmni/Documents/Albatros2/dokumenty/Ni1000.pdf
Trying to retrofit a pool BMS system with a pile of these in the field...
Cheers Chris
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,226
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,660
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,135
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,076
Hello! I have RTD sensor with 4 wire and shield ( 2 red wire + 2 white wire + Shield) and I want to connect to 1734-IR2 module. But in the manual...
1,462
