Run Time File
Learning
Mar 2012
MB
Hi Guys. Trying to get a runtime file, that I have successfully loaded onto my PanelView Plus 700, to communicate with my MicroLogic 1100. My Communication all seems to match with the old runtime file that actually worked, but still won't talk to the PLC. No information or commands are displayed on the touchscreen. Is there something in the run time file I could have forgotten? What are your suggestions, could anybody offfer some advice. Thanks in Advance
Could you possibly have loaded a blank file? Try reloading. Is the comm cable you programmed the PV+700 with the same cable you are using to connect to the PLC?
Thanks for the tip guys finally got it working. The mistake I had made was using the wrong tags. Found the correct place to look for tags, which got the panelview looking in the right direction and the communication started working. Thanks for the help.
Hi All Does anyone know if its possible to run a .bat file stored on a panelview drive, via the HMI (maybe an active x control?) Ive got a...
11,562
Gday all, I'm currently working on a system that is using FTView ME running on a PV1500+ version 6.0. I have a datalog model created and all...
3,478
I want to run Exe file on Button Click in Citect Scada. I want to execute one exe file of program files in Citect Scada.
2,219
Hey i got a prob. We are investigating to upgrade a computer that run windows NT4 and going upgrade to Windows XP It have Intouch on it and a...
3,419
Hi all When i try to run Protool/Pro Rt version 5.2 sp 1, I get a message that i need to load a configuration (*.fwd) file.Where would I find such...
2,476
