Rush!! Need Wiring Info for SJ100
piscis
May 2003
241
I need to send a 4-20ma signal to the VFD for setting the frequency. Can someone please post or email me a wiring example showing which wires I need to connect between the 06 analog card module #F0-4AD2DA-1 and the SJ100 (SJ100-022NFU)
Can you email it to [email protected]
Hello, What's the typical inrush current for a 60W power supply? Is it a factor of 5-10? Is the inrush current based on the maximum rated input...
1,044
I have two 24VDC motors that draw a little under 10A nominal, but the in-rush is over 20A. They are driven with a 20A power supply but on initial...
1,678
Hi, Everyone I am a beginner to PLC. I am currently working on a project to build a door cycle tester. Allen Bradley Micrologix 1100 is used to...
4,272
Good Morning , I just installed some 1 hp Lenze AC Tech 480 Volt Drives. I have seen this with other drives also. I went with a 8 Amp B Curve...
3,902
What would cause the brushes in a 250 HP DC motor wear very bad on one side and not the other on a motor that was recently rewound. Also we find...
1,736
