RX3I coms to Arcnet
Msut419
Feb 2018
new york
Does anyone have a good plan on how to make a new RX3I communicate with an Arcnet network. As of now i have a 90/70 plc communicating with the arc net with genius bus card, it uses a coax cable and plug and is in the ring of the arcnet.
Is there a genius bus card for the RX3I that has the coax coms? or is there a converter to convert Arcnet to Ethernet possibly?
Just google Arcnet to Ethernet..
https://www.automationworld.com/article/technologies/networking-connectivity/switches-gateways-routers-modems/access-arcnet-ethernet
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
405
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
304
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
126
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
994
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
412
