S110 Servo Error F07476
swedeleaner
Dec 2013
Göteborg
147
Hey guys!
I ran into a problem today regarding a servo controlling a conveyor.
Hope you can enlighten me.
The servo is used as an endless rotation axis. Everything works quite well until something triggers the error code F07476 : "EPOS: Target position > end of traversing range"
I guess this error is triggered because the servo exceeds 360000.
Since I don´t use absolute positioning in this application, is there a way to deactivate it? Or just reset it once in a while so that it can´t exceed the the range?
See attached picture from "Starter".
I have very limited experience with servos, sorry if the input is bad.
I will try to fill in more if you need more info.
Other hardware / software used:
S7 Classic
S7-315F-2.PN/DP.
The servo is using DP-connection.
EDIT:
The picture quality was really bad, it´s p2576 and p2577 that is marked.
Great!
Thanks JRW, i will try that.
So, for my application it should be enough to just set it to 1?
Not connect it to any of the message bits in Starter?
Hi All I am trying to find a way to get the motor temperature that I monitor in starter over on my HMI. I start to get a feeling this was not...
1,946
Hi there. Even after studying some of Siemens' manuals and examples, I still can't make my motor move to the references sent by a GE PLC...
1,267
Dear All I have Sinamics S110 drive that I will use to control a conveyor belt in steps, I have a 10 meter long conveyor belt, on the belt I have...
1,123
Hi all, I'm having an issue where I was looking at the program made a change to one parameter downloaded the program changed it back to...
1,156
Dear Gents First a happy new year to all 🍻 I am playing around with a S110_CU305_PN controller and is trying to make it as automated as...
1,528
