S31 Bus Reg Failure Kinetix 5500
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello All. I have an alarm on a Kinetix 5500 servo amp that I am not sure if it means the drive is done or what. I looked at the alarm code in the AB literature and my search found 1 instance and it tells me exactly what the display shows and what the alarm is saying online with the processor. Since I don't have a spare drive, I am unable to troubleshoot that way. If more info is needed, I will provide. Thank you
I should also add, this is an existing system that has been running for a couple of years and this is a new problem. Thank you
Bus regulation is what the drive does to try and maintain dc bus voltage at a given level, perhaps if slowing down and if the load has inertia and creates voltage by acting like a generator instead of a motor. The bus regulator setting could be the cause try changing that, remembering any parameters as before any changes.
Dear All, I have build and HVAC control system for a big shoping mall, based on ABBs AC500 and using the CS31 bus. The air handling units (AHUs)...
4,978
Hi I have a customer who has come to me with an issue with his Klockner-Moeller PS31 PLC. I realize its pretty ancient and should be replaced, and...
2,314
Hello, One of our customers has several machines equiped with ABB CS31 plcs. We have KT92 and KT93 types. I have tried to upload the program...
5,010
This is as basic as it gets, but has anyone have any experience with the 90 series ABB PLC's which is there "brick" model? They use AC1131...
3,490
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
43
