s5-115u plc
mehmosh
Apr 2010
riyadh
hi i am dealing with s5-115u plc.now it has problem.the system is manually working normally but on automatic mode it does not work.there is no error indication on the cpu.may be the problem in any input or ouput module or in communication module.basically the system consists of different podiums and it moves up and down either by manually or automattically.be remember that all podiums are different but all using same plc for automatic control.but all podiums have the same problems.please help me how i diagonse the problem that what module is faulty,and where are the possibilities of problems that cause to stop the podiums.
thanks
mehmosh
thanks
mehmosh
If the system works in manual and there's no indication of a fault on the cpu then I assume "something" (a sensor, conditions not met or so) prevents your system from running in automatic mode.
Don't just assume a module is bad just because the system won't run in Auto mode.
Hello Dear, I am using a PLC SIMATIC S5 115U CPU 943B my problem that there is no output on CPU (943 B) ⚫️RUN STOP 🔘RUN 🔘STOP 🔘QVZ 🔘ZYK...
2,488
Dear friends, happy new year 2013. I have a problem with the s5 plc 115u 943b, the stop and basf lights are "on" and the digital output is not...
3,766
I have problem and I cannot find the fault. PLC stops 5 to 10 times a day and then restarts after 10 seconds. I used step5 ISTACK but it doesn't...
1,353
Hi, I have tried with the cable IBH S5-USB-Adaptor, communicate with the PLC above, but I can not! The response of the technical assistance of...
3,677
Hi All, I am a Plant Engineer of a Cement grinding and packing factory here in Lae, Papua New Guinea. I have a MEchanical Engineering background...
4,674
