[S5-155U CPU948]How to copy program code?
apple
Jun 2006
Taipei
24
Hi! Everyone~
I want to know is there some way can copy program code from one cpu to another cpu, and append it?
My system has two cpu948, A and B.
There is a function block,FB1 in cpu A, but not in cpu B.
So how to make cpu B has FB1 ,except I type the code again ??
BTW, I use PG730 to edit program.
Thank you !! :)
Using Step5, then select File->Blocks->Transfer where you can set the source/destination for the transfer and the block name you want to transfer.
Thanks, it's work when I transfer File to File.
Do I need stop PLC when I transfer File to PLC ?? Thanks !!
When you copy FB1 to plc B, it will not exist so you can do this without stopping the CPU. You will need to modify a block in plc B to call FB1, so you would transfer this modified block afterwards - again you would not need to stop the CPU.
Just a quick point to note, if you are going to transfer/modify the program with the PLC running make sure that you transfer FB1 to the PLC before you modify the existing program to call FB1 otherwise the PLC will stop.
Paul
i have an old PLC : S5 155U (CPU 948) i need to connect it to ABB PLC using Profibus-DP, ABB will act as Master and S5 as slave. I need to...
3,023
Iam new to siemens systems and trying to install S5-155U CC with a CPU 948 in a very old plant.The CPU is OK and RUN LED is Green and iam able to...
1,456
Hi~ I have a question about Intouch. this is,could Intouch directly read/write date(DD,DW,I,F...etc) from/to PLC via H1Server? assume all setup...
2,400
Hi~Everyone,I don't understand what mean this code, need your guys help, Thanks!! I have two FX block(FX131 and FX132) ,they call the same...
2,691
Hi~Everyone!! I have some question about datablock (DB)? 1.CPU how to exchange data via DB?? I have a two CPU in one Rack, one is PLC1-1 and the...
1,739
