S5 Analog Scale problem!!
glasdam
Oct 2007
Copenhagen
I need some help to understand this S5 code:
AN F 16.3
JC =M001
L IW 60
SRW 3
L KH 0FFF
AW
FDG
L KG 780
-G
L KG 0.312
/G
T SD 636
L KG 0
>G
JC =M001
L KG 0
T SD 636
M001: ***
What I do know:
Signal: 4- 20mA
Range: 0-5000 hPa
I/O moudel: 1794-IE8 (12 bit on Profibus)
IF F16.3=1 then I/O signal is Ok and the value are calculated to SD 636
IF SD 636 < 0 then SD 636 = 0
My problem is that can’t understand KG 780 and KG 0.312
I can’t replay any questions to day, but I will be back tomorrow.
AN F 16.3
JC =M001
L IW 60
SRW 3
L KH 0FFF
AW
FDG
L KG 780
-G
L KG 0.312
/G
T SD 636
L KG 0
>G
JC =M001
L KG 0
T SD 636
M001: ***
What I do know:
Signal: 4- 20mA
Range: 0-5000 hPa
This must be a S5-135U. KG is the format used to display floating point numbers
As curlyandshemp says, KG = Floating point, the FDG instruction converted the input from integer to floating point.
The programmer did the analog conditioning a long winded way as well. What he did as
Code:
 [font=Tahoma]L	   IW 60[/font]
   [font=Tahoma]SRW  3[/font]
   [font=Tahoma]L  KH  0FFF[/font]
   [font=Tahoma]AW[/font]
would normally be done quicker as
Code:
 SLW  1
 [/font]   [font=Tahoma]SRW  4[/font]
that is the most commonly used method to remove the unwanted bits.
Thanks for your answer
However this do not solve the main part of my problem the scaling part:
(IW60– KG 780)/ KG 0.312 ; (IW60 modified as you described)
Hello I m using Unity Pro XL. I want to scale my analog inputs. I configured the Analog Input Module as 0-4 mA and 0-10 V . What is the way...
2,992
Hi, I'm using a Micrologix1500 and it doesnt have the SCP (Scale with parameters) block. I have a 1769-IF8 analog module and need read the inputs...
3,759
Hi I'm trying to change the scale in a analog Input module in the module while online. I got a warning saying something like Module changes could...
2,063
I have an automated batching system that im using an analog scale to trigger automated valves to open and close. I have the programming done and...
2,355
Please help me... Is there any possible way to use AB IR4-1762 module for analog input scaling....?
1,183
