S5 and OP15/C1 Ethernet communication
arthur.hauer
Nov 2016
Paraná
34
Hello,
I'd like to be able to command a S5-95U through both OP15 (HMI) and Ethernet. Have anyone ever seen anything like this before?
I know there is the possibility of communicating with OP15, but while doing this, the HMI is inoperable.
Thanks,
Arthur
Hello Kalle,
First of all, thanks for replying!
Yes, it is possible to communicate with S5 through the OP loop-through mode, but it causes the HMI to be inoperable.
After some research, I found out a multiplexer connected to a TTY/Ethernet converter might just solve my problem.
For future reference, here's the muliplexer supplier link:
http://www.process-informatik.de/produkte/pg-mux-ii-fr-siemens&lang=en_&mt=
Arthur
The loop-through mode doesn't cause the HMI to be inoperable. The only consequence is that the OP won't perform life bit monitoring while in this mode.
It was possible to connect S5 to ethernet, connecting the S5LAN to a special HMI port.
Sorry if I misled anyone with my incorrect earlier reply.
Hi, I'm working on migrating S5 to S7 and I have a COROS OP15 HMi. I need to know the tags from the OP15. I would be great help if someone can...
1,709
I have an COROS OP15-C1 (6AV3515-1MA20-1AA0) that I would like to get an upload of the program. I don't know whether the project was written in...
2,228
i finished a new project by protool v.6 sp3 on win xp , i have S5 TTY Programming Cable when i connect to op 15 display transfer ready but when...
1,284
dears is there any SFC to handle the communication between OP15 display and S7 PLC? as i need to send and receive some data ( analog and digital...
1,439
Hello Everybody, I need a help on the above subject :- Scenario: We need to upgrade a present system consisting on S5 PLC, OP15 HMI and...
3,028
