S5 in vmware
mrtoastie
Apr 2012
london
Hi how do i import xp pro, which i have on my laptop within windows 7 enterprise, into vmware. I am told you hit the import xp link, but there is no import xp link in vmware V4.0. Thanks
hi
I'm not sure if you can do that.
The way I work is the way we all should work, I use a legal Windows XP installation Disk. Then I install Windows XP from scratch Virtually in the VM Player. From there on you can make copies, but, don't forget that you may only do this for back-up, otherwise you are working with the same license in more then one virtual machine.
What you want to do... making an image from an exsisting PC => I'm not sure, but, I think you can use Norton Ghost to make such image and that you can open this virtually, but, I never tried this so I'm not sure.
I use VMPlayer, so I do not know if there is something like import (to make an image in VMWare workstation).
Kind regards,
G
Greetings all. I am having a new problem with my VM. Host OS is 11 and VM OS is 10. I have two smaller monitors that connect to my laptop which...
593
So, I have a little dillemma I am trying to work through but I feel there is probably a better way. I've always liked the idea of using a VM in...
2,107
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,666
Hello Hivemind My wife has a legacy machine at her work which uses (or I should used) an XP desktop with a serial port to communicate with a...
1,114
I have a MacBook running Monterey. I have a VMWare Fusion virtual machine on it running Win10. On the VM I have the Rockwell toolkit loaded. I...
3,081
