There some tricks that I know and certainly some I don't.
You have seen the first one, a false BE. Here it also was a couple of jumps with no label and a 'hidden' BE at the end. It is also a trick to remove the segment indicators - then you will get a message that the segment is to long. If the segment indicator also is replaced by a 'fake' load command, then the hexcode will look ordinary, and be hard to trace (easier to trace NOP0 or NOP1). So the procedure will be; Search carefully through the code:book:.
Kalle
