S5 to S7 Data Block Mapping
russg
Aug 2012
UK
280
I'm in the middle of mapping some S5 data blocks to a S7 PLC. I've just realised that the S5 data blocks are all addressed by the while word in the Wonderware SCADA system.
For example:
DB200 D60.8 for the S5 is DW60 Bit 8
is that the same as the S7 for:
DB200. DBX61.0 ????????
or is it more complicated than that?
Thanks, that is very helpful.
So just to be clear on the last part of that chart.
If I have DB 200. D 20.7 in the S5
this is DB 200. DBX41.7 in the S7 ????? So the right byte?
If it were DB200. D20.15 in the S5
it would be DB200. DBX40.7 ????? So the left byte and the 8th bit?
Afternoon, I have a DB in TIA Portal V16 that is optimised. I cannot change this. There is an array inside that block which consists of 3000...
1,189
Hello all, PLC-programming noob here. I have multiple clients accessing some data on my Siemens S7 1211C PLC; some OPC clients and some direct...
30
8,392
Hey people, I have been using GET_NAME , GET_IM_DATA and ModuleStatus FB to get an info from Modules inside my program, but ever since and...
2,592
Hi, just wondering if I could get some advice when setting up function blocks (Currently using Siemens S7) using a STRUCT data format. Say I was...
3,080
Hi, Ok bear with me, I have an Array of Real in a DB ranging from 0 to 10. In ladder I want when count pulse = 100 move count into Array 0...
2,094
