s5 Upgrade
teh
Supporting Member
Nov 2002
140
Hi Folks,
If i Upgrade the S5 to S7 , Should i need to Upgrade the Citect
V4.2?? and Also Windows NT to XP??
Is new buy CP5611 can be run in NT os?
Regards
What you actually do is, of course, up to you.
If I were you (and I am looking at a similar job), I would aim to upgrade the lot. The system I would choose would be:
- S7 PLC
- Citect V6
- windows XP
- Comms via Ethernet (which I don't think you could do on the S5).
Some important points during any upgrade, are:
- How much down time can you get?
- How to ensure the system won't lose any functionality
- What steps you need to take. For example, upgrading from Citect 4.2 to 6 would require several steps, such as upgrading to 5.0, then 5.4, then 6.
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
153
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
205
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
189
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
119
Am asking if we can upgrade sd ram and cf card of panel view plus ab by a normal sd ram and cf card but Allen Bradley to save cost because in ab...
294
