S7 1200 Analogue Out of range Alarms
bgeary
Jul 2008
Lincoln
Hi
I am trying to find out if and where TIA Portal V11 provides "out of range" alarm for analog inputs. Do they just appear in diagnostics? I would like to use a [Bool] to create an alarm in a DB.
Bob:sick:
With other Siemens PLCs I have had the problem that under/over range check generate an alarm if the signal is 3.99mA. The 0.01mA may not be because that there is a problem but just because the attached sensor can function a bit below its nominal range.
I ended up making my own check that generate an alarm if the signal goes below 3mA.
Dont know about S7-1200, but I would guess it works in the same way.
Just had a strange one on a 4 In 2 Out Siemens S7-1200 analogue module. I am used to seeing the status LEDs as green or red, but I haven't seen...
2,091
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
81
51
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
302
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
125
