S7 1200 Cam Control
Demendia
Mar 2014
Athens
Greetings,
I want to create Cam Controller in a CPU 1215C. I'm thinking the use of a Sick Absolute encoder via Profinet to get the absolute value from the shaft i want to inspect. The point of this message is that i have not the encoder in my hands and i want to ask before i buy anything, if the CPU can handle this operation.
I have a program from S7 300 (CPU315-2DP) without the FM card that uses comparators and the absolute value from an absolute encoder via Profibus and it's working perfect.
Does 1215C can handle it? and if yes you suggest comparators?
Also notice that the speed of the shaft on the new project(1215c) will be less than the old one(Cpu 315).
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
34
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
277
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
98
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
133
