S7 1200 sinusoidal signal
Mar 2012
bangalore
19
can posiible to take RESOLVER output sinusoidal signal feedback to given to plc s7-1200 to control the position of system.....
if is not possible why?.....
plz help me...
thanks for ur help
No unless....
plz help me...
thanks for ur help
There is a resolver decoder card you can get for the S7-1200.
There are special chips that are designed to look at the amplitude relationship between TWO sine waves that are 90 degrees out of phase.
HAI PETER,HOW R U?
Having a servomotor inbuilt with resolver instead of ENCODER & then,we can use resolver decoder card to interfacing a s7 1200 plc to take the signal from the resolver sinusoidal (SIN & COS Values) to control the motor....
sorry for asking a repeat question.....
Actually RESOLVER generate a sinusoidal waveform naa sir.....& without digital moduler.. how can u interfacing to s7 1200 plc sir......
thanks sir
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
54
31
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
267
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
91
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
123
