S7 200 communication between PLC and PC
vguellec
Sep 2005
Orléans
Hi everyone !
I have a project with a S7 200 PLC, containing an CP 243-1 for ethernet communication. So far I use to communicate with VB application thanks to PC Access.
My question is : Is it possible to exchange databloc between my PLC and my VB application with a TCP connection (like on S7 300 or S7 400) ? What are the correct instruction ? NETR and NETW ? Has someone any exemple of List porgramme with the correct configuration ?
The point for me is to save the cost of PC Access and make the installation on site faster !
Thanks in advance for your help !
Vincent
PC Access is not that expensive, and saves the time of writing custom code to handle the communications. I'm not sure why you would want todo it the hard way, but best of luck.
Hi Crossbow !
Thanks for your reply !
That's true but saving 200 euros on a small project is always welcome and the extra development I will do, could be reused for next projects !
I've replaced OPC server for my projects with S7 300 by a TCP connection and I see only advantage : reliability, response time, etc.
So if anyone know how to configure a TCP conection between a S7 200 and a VB application. To be clear, I saw that it's possible to configure Ethernet connection with Microwin but instead of a port number like in a socket, there is a TSAP (remote and local).
Is there any link between this TSAP and the port of my socket ???
vguellec said:
Hi Crossbow !
Yes the TSAP is your access point and points to your socket
With Delphi and using a UDP component I connected to a PLC ( S7-300)... on the PLC side you define the IPadress and local an remote socketin a connection and in the PLC software ( I presume) you refer to a connection .
Eric
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,804
Dear Experts, Good day I have to make ethernet communication between S7-1200 ( 1215c) and Beckhoff PLC CX5010. My question here any expert can...
4,268
Developing Communication between Energy Meter(Indigo+ Schlumberger) & SIEMENS S7-1200 Hi Members, I am Currently facing a challenge regarding...
1,491
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,618
Hi ! Everybody ! Please..help me about communication between S7 1200 and inverter or any varispeed inverter had MODBUS support by module CM1241...
20
11,176
