S7 -200 counter
bara_hence said:
you can press f1 when you have the counter marked and get some info in microwin and if thats not enough ask more specific
But how to reset the counter?Is it automatically reset or some input give to it?i checked with F1 but did not get this point
regards
nadeem
Hi nadeem:
Are you talking about S7-200 speed counters? or only S7-200 counters?
To learning about speed counters the best is to run the wizard with any parameters and then look in the subroutine it has created, in order to understand it. It's not dificult, but you may use the manual anyway to know what is each speed counter variable in SM area.
For the normal counters the best is to test them monitoring online the variables. Play a little, they are easy.
Regards,
Lorenzo Rivas
www.nubitek.com
GSM/GPRS solutions for S7-200
Having trouble with a Siemens S7 226 counter being retentive. I have specified in the System block C ranges offset 0, 6 elements. However, at...
289
I have a current project replacing S7-200 PLC with S7-1200 PLC (6ES7 215-1AG40-0XB0). The program conversions are manually created. I just want...
1,752
Looking for example of the use of the HSC in a CPU 1212C PLC. Not sure of how to establish Hardware ID, and which input to use the ID1000 is it...
1,842
hello i want to know that how i reset a counter value automatically on a specific time(e.g at 2 am)or after month or one year in siemiens s7 200
2,098
Hi all, I'm converting a S7-200 program to S7-300. There's a counter being addressed as an open contact such as.... C1 --| |--- In...
1,418
