s7 200 plcs
tny
Jun 2005
usa
105
i have a question about s7 200 plcs. some of plcs have eeprom slot and i have to make a "program memory cardridge" whenever i modify its program. are there any s7 200 plcs without eeprom card? what are the differences between cpu 222-224-226 ?
Hi tny,
There's no need to use an eeprom cartridge. A program can be loaded directly into the internal flash memory of a S7-200 CPU. Other data like flags or datawords will be retained in RAM that is backed up for approximately 10 days, without the need of an extra backup battery.
The EEPROM cartridge is the little 'bump' just above the programming port. That same location can be used for a backup battery.
Check for catalogue ST70 on the Siemens website, using the link below:
http://support.automation.siemens.com/WW/llisapi.dll?query=st70&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=10805148
(Sorry I can't upload the file; too large 877kB - PLCS.net limits to 300kB.)
Hopefully I was of some assistance.
Hi! My friend is an electrical technitian who wants to know if it's possible to build a DIY memory cartridge with an EEPROM for use in S7-200 PLCs...
1,151
Hello everyone! At present, I have 2 PLCs S7200 and 2 HMIs TP170. I want to connect them together. However, I don't know how do I do? May I have...
2,854
We want to data collect from plcs and making archive.3 pieces S7-300 (Only exist mpi port)and 1 piece S7-1200 (exist ethernet port).We are looking...
2,068
I have been working to get a Siemens driver library called libnodave to work with Advanced HMI to give access to Siemens PLCs. I have tested on...
26
34,486
