S7-200 RS-485 Capabilities.
DesertDog
May 2003
North of Los Angeles
350
I have a customer asking for a quote on equipment that includes an interface to their Johnson Controls equipment using RS-485 or Modbus. So far the information is very vague and I'm hoping someone with experience in this area can let me know some options while I try to drag more details from them.
Hello DesertDog;The following link will take you to Siemens' S7-200 Tips and Tricks page, Communication section:
http://www2.automation.siemens.com/microset/html_76/support/tipps/tt-kommunizieren.htm
You will find a demo for setting up the S7-200 as a Modbus slave. Code is also available.
There is also a Modbus Toolkit you can buy for the S7-200, if you don't feel at ease with the first solution.
Hope this helps,
Daniel Chartier
Thank you very much. It looks like what I need. If I'm correct this would require their system to be the Master and I would make the desired data available for them to poll.
Will I need a PPI Cable for this?
S7 200 plcs communicates over rs 485..if the customer's equipments has rs 485 ports..then all you need is a straight D9 male connector and a cable..
however, to program the S7 200 plc you need pc/ppi cable!
hope this help.k
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
278
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,292
I have an existing Micrologix 1200 that read some analog values off of temp and dewpoint sensors. I want to replace the current sensors with new...
1,917
Hi all. Are someone was tried to connect HMI with only serial port ( rs232/485 ) to a PLC (S7-1200 + CM 1241 RS485 ) I have a machine, where is a...
1,250
Hi all, I've hit a bit of a brick wall and need some help. I'm currently trying to get a Siemens S7-1200 PLC to talk to an Eaton DE1 Drive I'm...
3,707
