s7-200 serial communication with flowmeter
It depends on the communications channel you use. Is it MPI or RS232? You didn't give us enough info for us to give you a clear answer.
Regards,
Sorry for that.. I use the same kind of port as the programming cable is using (RS485/PPI).. The flowmeter has a rs232 interface but on the way to the plc its converted to rs485.. I just have the schematics.. The plc is a S7-200 cpu224xp.
I hope someone understands what I mean feel free to ask otherwise
With this setup, you have to use the freeport mode. There's a good example to download at the Siemens site which just does what you need. You'll find it in the programming tips collection, but I don't recal what number it is.
Kind regards,
I did find two examples have been searching all day... Thank you for your time.. For anyone who wants to know it is tip 52 and tip 20....
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,625
Good Day All, I've a MicroLogix 1200 and Panel View 300 Micro installed on a package in process and its working fine. PV is connected with 8 pin...
3,621
Hi all, new user. New to PLC's aswell. I am struggling to programme a Micrologix 1200 series C (L24BXB) to communicate with a serial slave...
1,941
Hello I am a university student conducting a project on making WinCC v6 talk to S7-200 CPU 224XP. The thing is: - Slave PLC is located a way from...
10,322
Dear experts, I can't connect to Siemens s7 200, I have Siemens ppi cable but I don't have serial port on my pc so I used serial to usb converter...
4,546
