s7-200 upload problems
liubing
Jan 2006
Suzhou
i try to upload a program from s7-200 CPU,the CPU is CPU224 version 02.00, the software is STEP 7 MicroWIN V4.0.4.16,i can successfully upload all DB and SB,but for PB when i upload to 100%,the PG display 'cannot open IEC-1131 program block in
current mode',i don't know why.
sure there are somebody familiar with S7-200 here,please help me.
thanks a lot.
Hi liubing
Never seen this problem so I can only make some guesses.
Is the PLC in Run or Stop.
Is the switch under the cover on the PLC in Run or Stop.
Have you forced any values in the status chart or set it into a diagnostic mode.
Is there an error number with the message, sometimes the manual gives more detail of what it means.
If you find a fix please post it here so that I will know what to do if I see it.
Regards
Bryan
thanks a lot
thanks a lot
i already found the problem.
in S7-200 we have two mode:SIMATIC and IEC-1131,the program in PLC is written in IEC-1131 mode so i can't upload in SIMATIC mode,as soon as i changed into IEC-1131 mode i can upload all blocks.
Hello members, I have Siemens S7-1200 PLC (CPU 1214C AC/DC/Rly version 3.0) and I want to get backup from it. I know how the procedure works. I...
149
Hi all, I have existing S7 200 smart PLC system, I don't know what software version they used to program it. I use microwin smart version 2.3 to...
510
I am new to siemens and I am trying to backup program from a S7-1200. Firstly I tried to connect using TIA Portal V16, then it shows the program...
2,153
We have a Simatic S7-200 6ES7 214-1B01-0XB0 (relay output) that has a bad output. I want to reprogram to use an open output. I still have an old...
1,197
Dear all, I can read (upload) the plc project easily. But when I try to download it almost complete (like 100% downloaded program block also data...
3,985
