S7-226 to WinCC Runtime comms???
Scott-bc
Oct 2008
Vancouver
I have a S7-226 and want to use port O and run a cable from there to my PC that will have the WinCC Flexible advanced runtime application running. I tried using the RS485 PPI/USB siemens communicator but I guess Siemens said that won't work. They said it has to be their PPI RS232 communicator. Would I need a RS485 to RS232 converter to take the signal from the PLC then convert it into RS232 then because my laptop does not have a RS232 port I would need to convert it to USB??.
This problem is only tempory becuase in a week or so we will be getting a ethernet module for the PLC. What other solutions could I use?
Thanks for all your help.
Scott
The USB PPI communicator should work fine to communicate between a PC running WINCC FLEXIBLE and a S7 226. The PPI RS232 has the additional capability to download / upload applications from the newer HMI panels, however, for establishing communications between PLC and PC both the rs232/ppi and usb/ppi should work.
hi: I have Siemens PLC S7200 CPU226 . I want monituring WinCC (ver 4.01) with CPU226. WinCC have driver for S7 MPI protocol , but S7200 is PPI...
1,614
Its a S7-200 part # 6ES7 216-2BD23-0XB0 A customer sent me one of these to extract the program out of. I have zero experience with Siemens S7...
2,245
Hello everyone, I have inquiry for Siemens S7 200, CPU 226 CN. Its for Chinese market. Can anyone tell me how exact to take data from PLC? I've...
2,660
Hi All, I am trying to set up the communication between a G304K200 and a Siemens S7-226 PLC via serial PPI but it is not working and I did a...
1,422
Hi, Had anyone Have this problem, where the Siemen 226 CPU (s7 200CN) 6ES7 216 2BD23 0XB8 disconnect the Proface Model 3580207-02...
1,202
