S7 300, 315 - 2DP, communication to profibus
Boni1
Apr 2008
Nairobi
I'm having problems setting up communication between ab S7 300, 315 2DP CPU with an MM440.
I have attached some codes I was working on earlier - I'm not in a position to get to my FIELD PG right now to get the revised codes. These two codes I understand had a difference in Profibus address. I have since then changed that on the existing program to be profibus adress 3 both on the S7-300 and the drive. I have tried to read through the various posts and decided I needed some advice on the starter and S7 codes.
With regards to the hardware - I,m able to communicate with an ET - 200s station using the same cable and CPU. This is after downloading a hardware configuration suitable for this. So I don’t think there is anything wrong with either.
On STARTER, when configuring the drive - the software tells me that it can see the profibus communications option board. This means I have eliminated all the hardware involved in this. The only thing remaining is the configuration. I have even tried it with several CPUs and MM440 as well as MM420, but I seem to be missing something.
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
170
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,270
hi there its my firest time working with profibus and i have already install gsd and networked profibus in step7 hw config and inserted base...
2,517
Hi friends, I have a 315 2dp and et200m im153-1, when I configure it through profibus ,I get BF light ON in ET200m and ON light blinking. In...
2,787
I am installing S7300 CPU 315 2dp, when I give inputs the Input leds of plc are glowing but even if the output is high the output leds of plc are...
4,841
