S7-300 Array indexing in stl
Roamingoat
Oct 2007
Basildon
As a relative newcomer to the S7-300 its driving me crazy. Can anyone tell me how I simply address an array item in the form:
Array[index] where Array is declared as a single dimension array of integers and index is an integer variable? I am working in LAD/STL and can't get the syntax right.
L "DB3".CIP_STEPTIME["DB3".CIP_STEP]....X
L "DB3".CIP_TIM_ACC
+I
T "DB3".CIP_TIM_ACC
It wont be simple in STL and it is impossible in LAD.
Array indexing in STL requires you to create a pointer, and there are many variants depending on what type of data and what you want to do with it.
This thread has a generalised example of array indexing (L D[AR2, P#0.0]'s post):
http://www.plctalk.net/qanda/showthread.php?p=230787
It is generalised so much that it may be too complex for your use. But you can cut it down to what you really need.
Do you have SCL ? If you have it I strongly recommend it for array indexing with S7.
In SCL you can really write data.Array1[22]:=(data.iArray2[iIndexVar1] + data.iArray3[iIndexVar2]) for example.
To achieve the same line of code in STL will take lots more work.
Here's a cut down version of the generalised array access FC that will read a value from an array of integers.
Code:
FUNCTION FC 7 : VOID
TITLE =Read an integer from an array;
VERSION : 0.1
VAR_INPUT
  aiArray : ANY ;
  iArrayIndex : INT ;
END_VAR
VAR_OUTPUT
  iResult : INT ;
END_VAR
VAR_TEMP
  iType : INT ;
  iDBNumber : INT ;
  dwAreaPointer : DWORD ;
  iSize : INT ;
  bBOOL : BOOL ;
  wWORD : WORD ;
  dwDWORD : DWORD ;
  byBYTE : BYTE ;
END_VAR
BEGIN
NETWORK
TITLE =de-construct any pointer for input array
	  L	 P##aiArray;
	  LAR1  ;
	  L	 B [AR1,P#0.0];
	  L	 B [AR1,P#1.0];
	  T	 #iType;
	  L	 W [AR1,P#2.0];
	  T	 #iSize;
	  L	 W [AR1,P#4.0];
	  T	 #iDBNumber;
	  L	 D [AR1,P#6.0];
	  LAR1  ;
NETWORK
TITLE =read integer from array
//open db if required
	  L	 #iDBNumber;
	  L	 0;
	  ==I   ;
	  JC	indb;
	  OPN   DB [#iDBNumber];
indb: L	 #iArrayIndex;
	  SLD   4;
	  +AR1  ;
	  L	 W [AR1,P#0.0];
	  T	 #iResult;
	  SET   ;
	  SAVE  ;
END_FUNCTION
Here's an example in use:
Dear All , I have written a small program in SCL as below . ///////////////////////////////////////////////////////////// FUNCTION FC1:VOID...
2,431
Hi, I am useless at STL and not fortunate enough to have SCL. I am trying to do the following; MW1 := 6 MW2 := 400 DB100.DBW[MW1] := MW2 So store...
1,677
Looking for some help with an array of strings in SCL. I have an array of 99 string[98] I also have an array of 99 INT My first 4 chars of the...
2,496
Hi Guys: See attached figure. This is my UDT. Is there any way to populate my array using excel and then copying it to my program, instead of...
2,727
Hello, Using LAD, how can I generate an array of 50 numbers and then calculate an average of them? I don't know how to define an array as a...
29
11,498
