S7-300 Array of strings and SCL
JOLTRON
Aug 2006
MI
692
Looking for some help with an array of strings in SCL.
I have an array of 99 string[98]
I also have an array of 99 INT
My first 4 chars of the strings are a character representation of an INT value e.g. 0001
I want to convert these to INTs.
My issues is when I try to compile I get an 'Illegal parameter assignment' when I try using the 'LEFT' function.
I am calling it as described in my Hans Berger book but it just isn't happy.
Any ideas?
Code:
Inputs
VAR_INPUT
    Count:INT;
END_VAR
Outputs
VAR_OUTPUT
     TaskId:ARRAY[0..99] OF INT;
END_VAR
Inouts
VAR_IN_OUT
     TaskList:ARRAY[0..99] OF STRING[98];
END_VAR
Variables
VAR
    i : INT ;             // iterator
    tmpStr  : STRING;
END_VAR
BEGIN
    FOR i := 0 TO Count DO
       tmpStr := LEFT (IN:=TaskList[i],L:=4);  //  HERE IS THE PROBLEM
       TaskId[i]:= STRNG_I(S := tmpStr);
    END_FOR;
     strLeftToINT:=0;
END_FUNCTION
Cannot pass FC IN_OUT of type string to another FC, use a temp string instead.
Code:
VAR
    tmpStr  : STRING;
    tmpStr1 :STRING;
END_VAR
BEGIN
       tmpstr1:=TaskList[i];
       tmpStr := LEFT (IN:=tmpstr1,L:=4);  //  HERE IS THE PROBLEM
    END_FOR;
Your array definition specifies 100 entries, not 99 as you posted, and your for loop contruction means that you will process count+1 strings - is this what you meant to happen?
Damnit! I always forget about the temp string when passing to another FC :(
Thanks I will look at the shortly.
My arrays is defined as 100. But in the actual process I am only using 99. I use 100 so I get a nice easy number to deal with. That is also why I defined my strings as 98 (using 100 bytes when the 2 byte header is included).
I didn't catch my count number issue in the For loop. I will have to address that as well.
Thanks as always for the help LD!
It compiles for me now and it executes but I don't seem to be getting any results.
My goal is to pass in an array of strings and get an array of INTs back from it based on the first 4 characters of the string.
Seems simple enough but I am still struggling. Definitely do not feel at home in SCL.
I have tried making both arrays INOUTs so I have full read / write access to each of them
I have tried directly writing to an external DB and monitoring it in a VAT table but I am not seeing any changes.
From inside SCL am I allowed to access DB's symbolically? e.g. strings.string1 := 'test';
I'm going to read through my SCL / STL book some more but any help would be appreciated.
Code:
Inputs
VAR_INPUT
    Count:INT;
END_VAR
Outputs
VAR_OUTPUT
END_VAR
Inouts
VAR_IN_OUT
END_VAR
Variables
VAR
    tmpStrFull  : STRING;
    tmpStrFourChar :STRING;
END_VAR
BEGIN
    FOR i := 0 TO Count - 1 DO
       strings.int1 := i;
       tmpStrFull := TaskList[i];
       strings.str2 := tmpStrFull;
       tmpStrFourChar := LEFT (IN:=tmpStrFull,L:=4);
       strings.str1 := tmpStrFourChar;
       TaskId[i]:= STRNG_I(S := tmpStrFourChar);
       strings.int1 := TaskId[i];
    END_FOR;
     strLeftToINT:=0;
END_FUNCTION
Kabang....
Code:
       [COLOR=Red]tmpstrFourchar:='a'; //must initialise a temp string before being used as value from a library string block[/COLOR]
   END_FOR;
Wow, I've never seen that either. Good catch! I assume this discussion was in reference to S7-300, is that true for the newer families as well?
Yes mk I was dealing with an S7-300 plc. I haven't worked with strings much on the 1200/1500 series but I will try to test it out when I have a minute.
Anyways here is the final code I ended up with.
Code:
Inputs
VAR_INPUT
    Count:INT;
END_VAR
Outputs
VAR_OUTPUT
END_VAR
Inouts
VAR_IN_OUT
END_VAR
Variables
VAR
END_VAR
Begin logic
BEGIN
       //Initialise strings or the will not work in SCL
       tmpStrFull := '';
       tmpStrFourChar := '';
       //Set tmpStrFull to full string of task
       //Set tmpStrFourChar to the first four characters which contains the unique ID
       //in character format
       //conver the four character string to an INT
    END_FOR;
     //RetVal currently not used so set it to zero
     SetTaskIDs:=0;
END_FUNCTION
Dear All , I have written a small program in SCL as below . ///////////////////////////////////////////////////////////// FUNCTION FC1:VOID...
2,411
Hi, I am useless at STL and not fortunate enough to have SCL. I am trying to do the following; MW1 := 6 MW2 := 400 DB100.DBW[MW1] := MW2 So store...
1,661
Hi Guys: See attached figure. This is my UDT. Is there any way to populate my array using excel and then copying it to my program, instead of...
2,715
Hello, Using LAD, how can I generate an array of 50 numbers and then calculate an average of them? I don't know how to define an array as a...
29
11,426
As a relative newcomer to the S7-300 its driving me crazy. Can anyone tell me how I simply address an array item in the form: Array[index] where...
8,895
